Stereo Feedback
Q
quenchmasterc5
I am trying to find out the most successful way to eliminate Radio/Stereo feedback from the engine. What are the culprits? What are the potential fizxes? Thanks to all for the welcome to the forum. I appreciate it and am amazed at how well other Vetters respond. This is a good deal.
AL
rwd
Yes
Varies
If you could describe the symptoms a bit, someone may be able to help. Do you mean your are hearing noise/interference from the ignition system through the speakers?
Q
quenchmasterc5
Yes, it sounds like ignition, which is the most common feedback you would hear in the stereo speakers. It increases as you accelerate. I also hear static when the blinker is on.
rwd
Yes
Varies
A little bit of info about the car might help. Did you buy it new? Is it modified? How long has the interference been present? ['Feedback' would technically be the stereo system squealing from continuously reamplifying it's own sound, like Jimi Hendrix]. Where is it present- am, fm, cd, tape?
If it's just started doing it, have you changed anything recently in the electrical system or gone to aftermarket pieces like plug wires or different plugs? Or worked on the engine or re-routed anything?
I'm not an electronics guy, but that would be the place to start so that someone who is will have the groundwork...
