Stallion
Okay, say this is the situation....
You are in 3rd gear going, say, 45 - 50 MPH. And then up 100 - 125 meters is a red light and maybe a car or two stopped at it. So now you obviously have to slow down because the light isn't going to turn green before you get there.
Now, what would you do? Would you downshift into 2nd gear (when, of course, you are at a respectable speed and RPM, 15MPH and 2000RPM???) and then into first gear (again, low speed and RPM so you don't grind)? Or would you just take off the accelator and then when the engine bogs down just push the clutch in?
The only thing I would worry about all the way downshifting would be not slowing down quick enough. But to push clutch in so soon would probably be tough on the brakes.
What would you do?
Thanks!!
What would you do?
Thanks!!
