M
MusclesWit350
In my 80 L48 I was wondering if it would be better to put a open air filter on instead of the stock set up?
I traced the bottom of the air filter onto 1/8" masonite board, cut it out then put it in the bottom of the air cleaner with the air filter on topThat way it still filters out all the junk and I can still use stock sized filters.
I looked off and on for a filter that was exact in dia. and 1/8" higher, but never found one, so one day I used cardboard cutouts until I found the height that I could still use the original carb bolt yet get the max clearance with air to the carb and still get the hood to close properly
Bud
