E
ediconu
I have a quick question, I found some info on the forums, but I'd like a bit more.
This morning, I was driving to work, i found an empty straight-away and decided to go a bit over 100 MPH. Since I'm driving down I-66 inside the beltway, this area without people on it went away quickly, and I had to slow down to the 8 (eight) miles/hour that everyone else decided was the speed to go.
I had some distance before i had to stop entirely, probably about 350 feet so I didn't hit the breaks too hard, but it started immediately violently shaking. I don't think it was a problem with the discs having pad material melted onto them, because i've stopped many times before and after that, in harder and softer fashion, and it hasn't done it other than that one time.
Does anyone know if the ABS on a '95 would cause shaking like that? The reason I suspect the ABS is because my mom had a '95 GM minivan and I was driving that one day, I had to break in the rain and the ABS on that made the whole car shake in a very similar fashion.
Does this sound like it should've happened?
-Mike
(BTW: I read this already- http://www.stoptech.com/whitepapers/warped_rotors_myth.htm )
-Mike
