- Thread starter
- #21
Tyler Townsley said:I love it when someone talks so technical.LOL But yes that is what I was talking about. When you let off it will pull down and cause symptoms you discribed if the bolt is not tight.
yes, i know, I'm just full of techinical industry terms!
LOL
one my car that that differential mounting custion (yes, it's the proper name of the part - I looked it up in the LICS cat.) is worn and shrunken. I know this and it had been causing a slight rubbing on the tunnel housing during hard acceleration when i first got the car so until I got a replacement piece my mechanic shimed it up. I did check that bolt and it is nice and tight. This is definately a different sound than i was getting previously through when the drive shaft was hitting the housing.
of course, maybe it's hard to check that bolt when the car is on the ground and i'll check it again when I can get the car up on a jack or on a lift. I got a replacment cushion now anyway so I need to get it installed and i'll make sure the bolt is tight when they do that.
