klyons
I have a friend who's 86 has the ignition key stuck in the ignition won't come out. No matter what we try. Any Ideas.
bossvette said:Here is a fix for a C3 may well work the same, reach down at the bottom of the steering column just above the floor and turn/wiggle the column while trying to remove the key. I rode around with the key in mine for about 3 months before learning that tip. The lock-out gets out of line and won't allow you to remove the key.
