Sun Visor Warning Label
MCMLVII
PROVING GROUNDS
BLACK 57, blu 15 vert
Any suggestions on how to remove the warning label on the inside of the sun visors?
Thanks.
Bob
V
VAmagred01
I haven't removed mine but I would think it would just peel off. If you have residue then try wiping with an alcohol pad. Just a suggestion.
Good luck,
Kenny
rwd
Yes
Varies
They changed the glue after 2002. I've read reports the later labels are much harder to take off. Both successes and failures have been reported. Sorry I can't be more helpful. At the least, it'll probably take some solvent to get the remainder of the glue out of the nap.
