gotoyz
New member
just joined this site so I'm looking for some noob sympathy.
I will disclose right now that this question concerns a custom installation
of a c4 front suspension on my 68 camaro.
what I have is an early c4 front suspension, 86 to be exact. I have learned
that big brake options for the earlys is very limited in comparison to the lates.
I am considering swapping out the early knuckles/spindles with later c4
pieces while retaining the early control arms. I am not using the abs and the
placement of the steering arm is something I can workout later.
it is the late c4 brake bracket mount point that I need for the brake kit that
I am planning to use, wilwood 13" six piston yadayada.
I mostly need to know if these knuckles are the same height and rotate about
the same axis ball joint to ball joint.
any guidance would be greatly appreciated.
