B
Bill
The targa top is coming loose. Is there a glue that will hold. I have tried most everything. It is a 86 vette coupe.
Bill said:The targa top is coming loose.
:LJT ZR-Won said:What exactly do you mean when you say the targa top is loose?
Turismo said:When I bought my vette the top was comming apart where the fiberglass meets the aluminum mounting brackets. At speed this caused the top to lift, pulling air in from the outside. Very annoying, and noisy. I have noticed on other boards people have posted the same problem with no idea how to repair. I fixed mine the proper way, and it is now stronger than as it came from the factory. I am just going to breifly explain here how to fix.
