cinci5
I just took the car to the body shop for painting and on the way there the check engine light came on. I stopped at a light and the car would not idle below 1200rpm. I got to the body shop and shut the car off while I looked for the paint guy. Found him and went to move the car for him and it would not start it cranked over though. I popped the hood and took off the air cleaner and tried to start only to find that the injectors were spraying as if it was at full throttle and it flooded the engine. I disconnected the battery and waited about 10 minutes for the gas to dissipate somewhat. I tried to restart but the injectors were still spraying at full spray. I did check the volts at throttle position sensor and it was .527. Was going to jump the pins to get codes but dont know what they are even if I did. Any help for the old f*rt please. Any thoughts any one.:cry
