I just changed the injectors and was letting the car warm up before driving. That is the best it has idled since I bought it. However, when I got in to drive it I noticed the temp guage at 260 degrees. I know it can't be that hot after only 15 to 20 minutes idling in cool night air. I did have a small coolant leak at the throttle body that I fixed and also had to take one bolt out of the thermostat housing to take off a bracket and lost a little coolant there.
I heard gurgling when I shut it down. Did I get air in the coolant system and would that cause the errant reading? Would it be ok to drive short distances until I can bleed the system??
