Kid_Again
- Joined
- Jul 6, 2004
- Messages
- 1,171
- Location
- NJ - Which exit you from?
- Corvette
- 65 SB Roadster, 66 BB Coupe
i have the correct shp oil pan on my small block, bought it at carlisle, i think...
...i have ALWAYS had an oil leak at the drain plug and it just ****es me off...i have tried every conceivable type of washer with the same results - a slow leak - and even though the car sits on the lift with a drip pan underneath, it drives me crazy
ad
.....i'm on the verge of just buying a moroso or milodon pan and my first question is which pan will fit - is the standard sbc pan OK or do i go with the notched variety for a ChevyII?
....or, i could try and fix the booger that's in place now....do these pans also leak from the weld for the threaded insert?....i understand that an "oversize" drain plug is available and that might be a fix........
any thoughts?
any thoughts?
