Did you ever dream that getting fuel from the tank to the carb could be this complicated? :crazy
After two tries at it, we finally removed enough length from the clutch cross-shaft so that it would work well with the custom pivot ball bracket.
Also, the new battery and cables are in, the electric fans and relays are pretty much wired up, the headers are properly mounted (after a long wrestling match with head bolts and ceramic coating, etc.), thick cork valve cover gaskets are substituted for the type that came with the ZZ-502 (wouldn't work with the original valve covers), the updated combined alternator/regulator, new pulley and fan belts are mounted, etc.
Could that be some sort of white lithium grease??
