T
Ted Krempa
I have seen reference to the 'Opti' on the board (and not to get it wet !) Can I get the short version of what is the 'Opti' and where it is on my 96 LT1
Thanks, Ted
Thanks, Ted
6 Shooter said:I power washed my 96 LT4 Grand Sport Motor twice when I owned it with no problems.
tedkrempa said:thanks 6, no hosing off the engine right ? if so, how do we clean the engine bay ?
Ted
6 Shooter said:It's on the front of the engine under the water pump.
Here's a few opti links for ya . . .
1992: Campaign: Optispark Distributor
Corvette LT1 Opti-Spark Ignition
Hope this helps.
Later . . . . . .
6 Shooter
I take the Steem Jinny to them all the time,and have never had the First one not Start!! junk!!Vettelt193 said:dodged the bullet
for the rest of us, simple green is probably the most common method of cleaning:ugh
Hrtbeat1 said:Under the Air hoses and just behind the AC accumulator (the shiny thing in 6 Shooters pic.) If you follow the spark plug wires one end will go to the spark plug the other will go to the opti. The water pump is just above the opti. I think you can just see the edge of the opti in Shooters pic (the white thing back in there.)
