Thinking of installing a Magnacharger.
E
ELECTRONJMB
After reading the article on this site, and deciding I want to treat myself to a chrismas present, I was thinking of supercharging my 02 6sp convert. I would like to hear from anyone who owns one of these badboys and drives it on a semi daily basis.
Jeff
Redlite
New member
Grand Ledge,Mi
2000 Torch Red Convertible
I drive a 00 Vert with an Intercooled Maggie and some other goodies all summer in Michigan. The polished Mag is a show winner and the POWER is addicting. I'm now about 500rwhp and 525rwtq so I'm about at the end of the stock motor's capabilities.
GO FOR IT...............Randy
Mr. Lucky
Orange, CA
2004 MY stroker Coupe
Therein lies the risk when going with a Magnacharger. It is a superb and relaible setup, but once there, you are maxxed out. If you ever get the "itch" for more power, you have to start over again. That's why I went with a 402 stroker instead. It has similar power and low-end torque, but can be expanded almost infinitely (blower, turbo, larger cam, etc).
Of course, the Magnuson wins hands down in the :cool department.
M
MagikDraggin
In your experience, how is the 402 in the reliability department, as compared to a reasonably "stock" (usual bolt ons) 346 5.7 ltr?
Mr. Lucky
Orange, CA
The stroker has been very reliable. If you think about it, it should be as good or better than stock in that regard. It is still NA, and has the benefit of being balanced and blueprinted, using all top quality parts. Valve springs should probably be pre-emptively replaced more often than stock, unless you go with a very mild cam. I have ~ 13K on this block and all is well.
Here is my dyno sheet, showing SAE power at the wheels through an A4/tc. This platform still has lots of room for growth, should I so desire.
Mr. Lucky
Orange, CA
Price varies, depending on what else you have done. I added a FAST 90mm manifold, LS2 tb, ported AFR 205 heads, Harlan Sharp roller rockers (stock ratio), 228/232 114 +4 cam, and thermal-coated LG Pros w/ hi-flow cats. Of course, the entire rotating assembly is forged as well. This is a completely new LS2 short block with a 4" stroke. When I compared the price (installed and tuned) to a polished maggie and MCM hood, it was very close.
If you re-use your LS6 manifold/tb and substitute something like Patriot heads in the stroker, or use a lesser grade hood and non-polished maggie for the blower configuration, you can do it for under 10K complete. Either way, you can't go wrong.
Norman Clemmer
Green Lane, Pa.
Blue 2003
Jeff
32K + miles after Maggie install no issues. If you do it you will never be satisfied driving a stock vette again.
Win Both Corvettes!
Win Both Corvettes and Get Extra Bonus Tickets Now!
Dead Center Foundation
