boomdriver
I took the Vette for a quick ride. The noise is still there. I guess it didn't heal itself over the past few weeks. The noise is louder under acceleration than at steady speed or deceleration . I jacked up the car and looked at both sides while running. Didn't appear to be any tire/wheel/alignment problems. The tires ran "true" w/o any variation on either side of the car.The noise is definitely coming from the bearing/hub area. I rotated the tires by hand and didn't "feel" any difference from one side to the other.The only difference when I installed this ass'm. was the addition of the "thrust" washer. I'm almost certain that I placed it on the spindle correctly . It seemed obvious when put on the spindle that there is only one way to do it.
My question, after this long explanation,is: Can a bearing ass'm. be "bad" from the manufacturer ? I rotated the new "brg. ass'm." by hand prior to installing it and didn't notice anything . Is there anyway to test the brg. w/o any special tools ?
Again, thanks in advance for any and all replies.
MiMitch.
The cheaper chinese made bearings are looser, sometimes so loose that they are at the outside of the spec for replacement...but, I've never heard of one that makes noise. That comes from a needle or ball thats been flatened inside the race and "clicks" as the load rolls around to that spot. This is wear and lost lube, so its highly unlikely that a new bearing would make that noise.
Sounds more like a U-joint. Go thru the motions of shifting rev/for and listen for some slop in the drive train. A worn joint in the drive shaft can sound like its in the half-shaft because of the ability of sound to travel the length of the drive line.
