Peer81
Hello everybody,
I want to know something but can't find the answer on the net so here it goes.
In short, why do we only set initial timing at idle and not the initial + mechanical timing above 2500 - 3000 rpm like the older ones?
As I see it, initial timing is set by hand so is the same as the older dist.
Mechanical advance was set by weights and springs on ours is set by the 7 pin ignition module and can only be changed by a different ignition module.
Vacuum advance was controlled by the vacuumline to the intake on ours is controlled by the ecm.
It this about right?
I also found this topic from Sensei:
http://www.corvetteactioncenter.com...ry-forum/98701-81-ccc-performance-timing.html
So why not set timing to 36 - 38 degrees at 3000 rpm?
Greetings Peter
Greetings Peter
