On an L98 using the stock engine controls, timing is controlled by the engine computer and is not adjustable.
All you can do is check the base timing, by disconnecting the timing connector, then setting the timing to whatever the FSM says the base timing should be for your model year. Seems to me that most of the L98s base timing was 8°BTDC, but I'm not sure on that.
