Beobachter
Just upgraded 87 C4 from 16" to 17" with 275/45's. What tire pressure is best for these? I assume same as 88 with standard 17's
A tire's listed pressure is simply a maximum pressure needed to support the maximum weight the tire is rated to. Your goodyear most likely has a max of 44 or 51 psi. But you do not need anywhere near that. The only time I could see going above 40 psi is if you were autocrossing or doing a HPDE. This is done to help stiffen the tire when pushed to its limit (and beyond) at these types of events. Should you choose to run these pressures on the street your dentist and local tire shop will be glad to see you often. Dentist to replace fillings rattled loose from the firm ride. Tire shop for rapid tire wear in center section of tire.Moonunit 451 said:My F1 D3's are like 55. What's the tire say?
