On every car I've ever owned, Corvette or not, I've always used the factory-recommended tire pressure from the sticker printed on the inside of the driver's door. After all, why use something other than what the factory recommends?
'13 427 60th vert - '21 Silver Flare Coupe - CTS V Wagon(4-door Vette)
I'm with Partick on this one - 30 psi or whatever the sticker says.
This assumes that you have matched the tires with the wheels - if you're going to run a tire/wheel combination outside the tire manufacter's recommendations, then you're on your own.
I heard that because the side walls are smaller a
few extra pounds of presure will help prevent damage
to the rims. With the condition of the roads around here,
pot holes, any help would be appreciated.
Len
