rmagee7
tire size, got a great deal on some rims what is the difference between a 245 and a 275?
Here is a neat web site where you can visually compare various wheel diameters, offsets, and tire sizes:
http://www.bigcustomwheels.com/info_specs.jsp
I used to use that dodge drl tire calculator..but the big custom wheels BLOWS IT AWAY!
To make it easy I will use my tires as an example 275/45/17.
This means 275mm (10.8in) wide (the patch that comes in contact with the ground), 45mm from the edge of the rim to the outer edge of the tire, and 17 is the diameter (17in) of the rims.
Are you sure about this? I have always been under the impression that the second number (45 in your example) was the "aspect ratio" or the percentage of width (275 in your example) which would make the sidewall
123.75 mm high.
If you go by your figuring a standard 275/40/17 tire would be 20 and almost 3/16" tall....ah but not so. If you go by percentage it would be
275 X .40 = 110mm for the side wall height ( times 2 ..top and bottom) the 17" wheel = 431.8mm so add the wheel diameter plus the two side wall heights 220 and come up with 651.8mm tall....divide that by 25.4 (mm/inch) and come up with 25.66" which is very close to the specs on most 275/40/17 tires.
Thus, the second number is an indication of sidewall height, but it is a percentage number in relation to tire width.
Yeah, the 1st number is the width of the tire, the 2nd number is the sidewall hight, and the 3rd is the rims size.
You are right, I did not even think of 40mm (4cm). That is pretty small. I dont know what the 2nd number is? Maybe it is the sidewall before the tread. That would be about 4cm.
GIVE THE MAN A CIGARHere's the math on the above tires.
205/40 205 x .4 (aspect ratio) = 82mm 82 x 2 =164 (two sidewalls) 164 + 431.8 = 595.8 (two sidewalls plus the wheel diameter) 595.8/25.4 = 23.45" (Height of tire in inches converted from metric)
245/40 245 x .4 (aspect ratio) = 98mm 98 x 2 = 196 (two sidewalls) 196 + 431.8 = 628.8 (two sidewalls plus the wheel diameter) 628.8/ 25.4 = 24.75 (Height of tire in inches converted from metric)
255/40 255 x .4 (aspect ratio) = 102mm 102 x 2 = 204 (two sidewalls) 204 + 431.8 =635.8 (two sidewalls plus the wheel diameter) 635.8/25.4=25.03 (Height of tire in inches converted from metric)
275/40 275 x .4 (aspect ratio)= 110mm 110 x 2 =220 (two sidewalls) 220 + 431.8 = 651.8 (two sidewalls plus the wheel diameter) 651.8/25.4 = 25.66 (Height of tire in inches converted from metric)
Again not to belabor the point, but, with your reasoning a 315/35 x 17 tire would be 19 3/4" tall they are 25.6 (or very close to it)
