Yes, you can. No, you shouldn't.
Macgyver said:
How will that go, do I just run the lines to the AC cooler and it will do its own thing or do I need a pump of some sort. Im really tired of spending money this week.
The tranny has it's own fluid pump to send fluid to the converter and this is what moves the fluid through the radiator. No additional pump is needed, like in the rare differential coolers you find on some vettes (some of these also flow without a pump, just from the differential pressure from the cooling of the fluid - but that always seemed "iffy" to me, especially with something as viscous as differential fluid.)
BTW, I am still crying from the evil "bubba" remarks...hehehehe.....
You CAN do this (use an A/C "condensor",) in fact this is where most old style "bubba" auxilliary oil and tranny coolers came from - either automotive or window unit A/C "condensers".
Ready made/bolt on kit coolers from the 287 people who make them weren't extant as recently as the early 80's - and those that were around were pricey.
There's the rub though - they have some NIFTY and SMALL ones that are quite reasonable now - but ALL of these are really rated at being AUXILLIARY coolers. They usually run the plumbing from the standard on-the-coolant-radiator one to the auxilliary one and back to the tranny. This will cool the tranny way below the percentage of the engine coolant temp, which it picks up some of - sort of "polishing" the cooling process, down to a nice <35-50 degrees over ambient maximum.
Absolutely send the radiator back and get the right one. I know it's a pain.
THEN as several posters also recommended, you should definitely get the highest GVW/temp reduction auxilliary cooler you can fit, without getting silly on costs.
You should be thinking an auxilliary oil cooler too with Texas heat. Even running Mobil 1/Royal Purple/Red Line/Castrol/whoever's full synthetic, breakdown and working viscosity are very negatively affected by even modest increases in oil temp above 220 or so.
Back to the tranny though, I have a Turbo 400 which is hopefully a refund check away from getting a Gear Vendors Overdrive added. It has a mild stall converter - an 11" about 1875RPM. I just recently had it (and the converter)rebuilt (reverse died, badly
), a nice sharp shift kit installed, having an electronic speedo sender put in for my new Nordskog panel AND having a tranny temp sensor drilled and tapped into the case from above for the auxilliary gauge panel I already had on the extremely "bubba'ed" heap.
I just made a "rescue run" for some silly relative who missed the bus back from Bossier city (from Dallas) yesterday. Holding a steady 90-95 for the 210 mile one way trip, with an engine RPM of 4200-4500 (I have 3.73's in a Tom's Differential 12 bolt), with an air temp peaking at 75, the tranny temp made it up to 182, and was usually over 175.
That's too high. Not a lot, but some. 160 - even 150 with such a low air temperature would be more ideal. When we get to 105 in a week or two for the next six months, it's probably going to see 210+. I'm gald I use Royal Purple full synthetic, but that won't save those bands forever (even though they did make it for a hard 45,000 miles in the 18 months I've been abusing the poor thing.)
Now my mild stall converter will raise the temp a LITTLE, but the neck braking shift kit will also lower it. (The former increases higher rev slipping a little in exchange for harsher take off, and the latter eliminates a lot of heat-inducing slip and ALSO happens to yield a much better painful shift!) So it's pretty much a wash there compared to a stock tranny. The higher RPM operation in front of the pumpkin makes the tranny pump run faster than normal, thus increases cooling (within the limits of the heat transfer capacity of the cooling appurtenance - which for a very short while is just the plain "in-radiator" one.)
A non-lockup converter overdrive generates an ENORMOUS amount more heat and turns slower (at the fluid pump) to make the problem worse. While not in consideration here in either case, I BELIEVE a lock up converter is much better for this, but am not sure. The converter is where something like 65-75% of the heat in a tranny is generated though, as I recall. (Notice manual trannies and differentials rarely have coolers - generally only at high speed or power levels.)
Good Luck and good luck on the tranny swap!
