- Thread starter
- #21
D
dreamboat3annie
okay jj :bang
jjones said:Hey Dreamboat - any major mods to your Vette (mechanical or structural) will void the warranty. Cosmetic stuff is OK. Another reason why not to.
jj
les said:I would use the money to buy some cool ground effects. Mabe a wing.
panzer said:What is the relationship between lowering and tire wear if your driving stays the same?
Heres some C-4 lowering instructions for yea!!! It's so easy to do! Infact, the hardest thing to do is to cut the rubber off the spring.. that stuff on there is tuff!! Unbolt the outer tie rod & sway bar, on both sides, losen the spring retainers which is holding the leaf spring to the frame of the car. On either side that you what to start on first, get a block of wood ( 2 by 4 ) and a small floor jack will be fine, put the wood along with the jack under the spring closest to the a-arm, with out it being ON the a-arm it's self and slowly jack the spring up untill it's not resting on the lower a-arm ( about a 1/4 to an 1/2 inch off ) Disconect the ABS sensor thats located on the brake assembly, thats very important for you to do so!! ( if yours has one) remove the 2 bolts that are holding the shocks to the lower a-arm (they're located near the spring in the lower a-arm), unbolt the lower ball joint stud nut, you can use a two jaw puller or what I did was unscrew the nut untill it covered the end of the stud and with a hammer, tap on the top of the nut and not that hard or you'll ruin either the nut it's self or the stud or both. (try using a hard rubber mallet first) Before doing this, find something to put under the wheel hub.. another block of wood would be fine just to stabilize it and it should come free with no problem!! repeat this on the other side and let the presure off from the 2 by 4 and jack free and you should be able to slide the spring out from either side after you pull back at the wheel hub away little, the spring will slide out from the lower a-arm. It will not come out all the way if the car is not jacked up high enough and it does not have to!! you just need to be able to slide the spring far enough to be able to reach the rubber mounts. With a steak knife or I prefered a hack saw blade, saw off the rubber mounts and try not to cut into the spring it's self... take your time, don't rush!! (Helpful hint- While sawing the rubber piece, lift up on the piece that you've already sawed on, away from the spring while your sawing, that way it will not bind it's self between the rubber and spring. please remember this hint, it'll make work a heck of a lot easier for your self!!!). do this on both sides. this will give you the drop that your, I think looking for!!! The wheels will be, depending on what size rims you've got, if your running stock 17's will be about an 1 inch to an 1 1/4 from the fender wells, and NO!! THEY WILL NOT RUB!! You will have to of course hopefully with out saying, take the wheels off to do this job, and the ride is fine, just a little more stiff, and I do mean, A LITTLE!! This will make your car low!! I hope this helps Aloha!!madquake said:Where Do I find a step by step web site on how to Lower my 93 convertible Vette ??
Please I have the bolts and shim thingy here to do it ... Please anyone ??
Thanks Mark A ..
Send link here or to madquake@bellsouth.net
Thanks a million guys and galz!
Da Hawaiian Punch said:To who's ever intrested, I just copied a response that I had made to a fellow forum member.......you'll see why I copied and not wrote it out again.....it's longggggggg!! This is the instructions for lowering the C-5 (Important Note) If you have that ride control thingy, I'd fine out if your able to do this or not, reseach first before attempting this project.
First of all, how low do you want to go? is the most important question, you see, on the C-5, it has a true adjustable suspention, so if you want to go only as low as the adjustable suspention will let you go, just jack the car up, take the tires off, look in the arm section behind the bottom part of the shocks, at the fiberglass leaf spring where it sit's in the a-arm, you'll see a bolt/nut like thing in the middle of the leaf sprinf that sits in the bottom of the a-arm, just un-screw the bolt all the way out, dont worry, it can't come out all the way, it'll stop at a curtain point, put the tires back on do the other side of course, and drive a few feet to let it settle down to it's rideing height, now if your looking at slamming the car all the way down like what you see in the pictures that I posted this is how you do it,........Jack the front of the car up HIGH!! at the right places, and support it on jack stands, now, unbolt the "sway bar", un bolt the shocks from underneath, disconnect the abs sensor (If you have one) and be very careful doing so, get a floor jack, and jack the a-arm up a little and set a stack of blocks under the wheel rotor then let the jack down, with another block of wood, set the jack under the leaf spring on the bottom of the car, now, when you set the the jack with the wood on top of it under the leaf spring, make sure that the wood is as close to the bottom of the a-arm with out resting on it, you'll just want the wood and jack on the leaf spring, now jack the jack up just a little to take a small bit of pressure off the a-arm, back the nut out a little on the a-arm ball joint untill it's flush with the bolt that it's on, with a ruber mallet of a block of wood and a hammer, strike the top end of the nut & bolt, after a few strikes, it'll break free, (note)- this is to be done only if you dont have a ball joint seperater. Once thats free, jack the leaf spring up more untill the presure on the a-arm is gone, take the ball joint nut all the way off now, and the lower a-arm it'll be free floating, you should be able to push it down to the ground, now you'll have free access to the bolt thats on the leaf spring, take off the retainer clip, and unscrew the bolt all the way out! do this on both sides. now un bolt the 2 spring retainer's thats under the car, they are 2 metal clamps, that have 2 bolts through them, which are bolted to the frame of the car which holds the leaf spring in place, take them completely off. Now go to either side and pull the spring out, just enough to where you can get a steak knife of hacksaw blade to the rubber bushing thats glued on to the spring, saw that piece completely off! (HELPFUL HINT----At the same time that your sawing the rubber bushing off, lift up on the rubber bushing, away from the spring, that way, the knife or blade will not get caught between the rubber and spring, if you dont do this, it'll take you hours instead of minutes to cut the piece off!!) Now put the every thing back together and your done!! You'll notice that the other side will be much faster once you've done the first side! It took me about an half hr to 45 min to do the first side and about 15 mins to do the other side!! I hope that I explained this clearly enough to you and that it helps you!! The rear end?! All you have to do is take the floor jack with the block of wood, jack up the leaf spring on the rear, unbolt the bolt thats on the end, put a longer one in it's place, (Grade 8) get about an 8 to 9 inch bolt to be safe! thats it! You'll have to do some adjustments to even the car out. Take it easy!! It's the same instructions for lowering the rear of the C-4 also!![/QUOTe
Can I just lower the back of my c5?
