top dash pad removal
71VERT
buffalo
66 Red 427 Coupe
How do you remove the top dash pad on a 69 convertible for replacement.
Thanks,
Jerry
Thats the question that started the creation of corvette forums.Through my research I found that the upper dash was installed first during the assembly of the car so it is a pita to remove with out removing the lower dash pads.It can be done.First I would remove the pillar posts and then remove the screws that hold it to the lower dash pads and the center guage cluster .Now you can remove it but you may have to slightly bend it to get the corners to clear the windsheild pillars.Good luck.:w
Thanks paintdaddy, does it snap into place or are the screws holding it to the lower dash pads all that hold it into place?
The screws to the lower dash pads are the only screws.The front is held on by clips that slide on to a track.You will have to pull toward you while removing it to get it loose from the front.Did that make since ,because I think I just confused myself? :w
The 77 has one screw in the middle of the dash underneath attaching it to a bracket. Can't be missed if yours is the same. Otherwise my experience was the same as Paintdaddy described.
My 72 has one screw at front of dash pad underneath also. Can get to it by removing right lower dash.
Mike
Thanks guys I will give it a shot once the new pad arrives.
Thanks,
Jerry
