V
vette-dude
I am about to re-assemble the upper plenum after changing the EGR valve and need to know if there is a Torque Spec for the Screws/bolts that attach the plenum to the runners. These are the upper screws/bolts not the ones on the manifold. Also, should I use never seize on the threads as the bolts are steel and the plenum is aluminum? Thanks in advance to all answers.
Randy
Randy
