This may be the my one minute learning lesson for today!yellow_2002_germany said:I have a 1/2in Craftsman Digitork that goes from 24 to 240 lb-ft. I love it. Always remember to store a torque wrench at its lowest setting when not in use if it is a click type.
MM-C5 said:This may be the my one minute learning lesson for today!
I learned to lay my wrench flat as opposed to hanging it, but why do you set it at the low setting? What difference does it make?![]()
Tom
bluecoupe said:Great torque wrench storage advise guys! Does anyone know if using a socket extention and/or an adapter (3/8 to 1/2 inch) changes the torque wrench accuracy?
74bigblock said:Yes, but unless you are doing motor work... you should be OK.
bluecoupe said:Does an extension add or subtract from the setting? I tourqe my wheels to 100 ft- lbs but use a small extention. Should I increase or decrease it a couple of ft-lbs?
yellow_2002_germany said:Here is what the Craftsman tools site says about my digitork wrench (25-250lb-ft):
Accurate to ±3 percent on clockwise or right-handed reading greater than or equal to 20 percent of capacity.
At 100lb-ft your torque will be 97-103lb-ft.
I don't think increasing by 2ft-lbs or so would make much of a difference.
