B
Bill C
Is there a difference between a 305 TPI system and a 350 TPI system other than the computer? I have a chance to pick up one and I need to make sure that they are the same. I have an 85 TPI set up and I have no idea what this box of TPI parts came off of. Looks like the fuel rails, thermostat housing, EGR set up, runners, throttle body and electrical componets are all the same.
Is the manifold base, runners, fuel injectors and plenum really all the same? If they are different how do you tell which is which if the unit is off of the engine and in seperate parts??
I know that the fuel line location and hook ups on non- Vette applications are sometimes different.
Are there TPI set ups for other GM applications that will NOT work on a Vette. I know that there are EGR differences on some vette years.
Bill C
Bill C
