corvette66
I just started on my TPI swap. Thouhgt I had everything figured out ahead of time but as I figured poblems always find their way into the plan.
Problem 1: Im using a stock 1986 camaro z28 harness and I'm not sure how to hook up the fuel pump to it. If anyone has ever used a stock harness you know there is 4 plug connectors after the bulkhead. 2 for the ecu, 1 for the fuel injector lead to fuse, and 1 plug to hook everything to the dash/ignition switch crap. Now on that plug there is a "main power" wire for the fuel pump. what i cant figure out is how should i hook it up so that it runs (presurizes the system) when the key is turned to the "ON" position but then it has to shut off until the motor is running. How is this done???? does the ecu and relay control this?
Problem 2: Anyone know where i can get a decent sized roll of high pressure steel fuel line? And should the return line also be high pressure? I know that it usually is, but does it need to be?
thanx guys
thanx guys
