Racer86y
How would i use fuel pump with carb?I have fuel line and return line,would i put regulator on return line set at 6 lbs or ?:confused
So i will have to buy another regulator besides the holley i have.It has inlet and 2 openings both regulated.Who would i buy regulator like this from?You would need a bypass regulator.
You'd connect the car's feed line to the regulator inlet, you'd connect the bypass out of the regulator to the car's return line and you'd connect the regulated outlet to the carb and set the regulator to the pressure the carb maker suggests.
Yep.So i will have to buy another regulator besides the holley i have.
Yep.
SX Performance makes good ones. That's what I use on my 71 which uses a bypass fuel system.
Do you have link to SX performance?:W
