69MyWay
77-4speed said:Chris,
Just to clear it up, they only scrape on hard left turns. Also, the bump stop on the passenger side is missing. I don't know if it is possible for the bolts to scrape on full travel in stock configuration without the bump stop.
So, I'll have it looked at hopefully this weekend and keep you guys posted.
-Russ
The side yoke is the rotating assembly that comes out of each side of the diff. The half shaft axle bolts to the side yokes via the inner U-joints. The side yoke cradles two of the U-joint swivels, and the half shaft cradles the other two.
The actually side yoke should have very little side to side movement. It has a C clip on the inside that retains it in place.
That happens is the C clip may have been left off by the last mechanic in there, or it popped/wore off. The pressure from the outside has pushed the side yoke into the diff carrier. Over time, heat, and pressure, the yoke slowly grinds into the center, resulting in travel in and out. When you turn the car, now the pressure is moving the yoke into the side of the diff.
I hope I am wrong. But, it is possible that the travel stop bumper is gone or is worn down. That extra bit of travel may be pushing it to the extreme. However, if the side yokes are healthy, you should be able to run with no stop busings, and turn as hard as you want, and the yokes would never scrape the housing.
