L
lakeview
i have a 2001 C-5 coupe, get alot of noise when starting out in first gear, sounds like its in 2nd ? only thing i can think of is pilot bearing,or throw out bearing? anyone hear of this?
C5's has allot of Clutch and Flywheel noise!!! Does it sound like a Box of Rocks or Marbles Rattling?? If so it's probably the Duel Mass Flywheel!! Thats Normal!!!i have a 2001 C-5 coupe, get alot of noise when starting out in first gear, sounds like its in 2nd ? only thing i can think of is pilot bearing,or throw out bearing? anyone hear of this?
Sorry,but it's true!!!
If it sounds like marbles in a can, it is normal for the C5. If you give it a bit more gas in 1st gear while letting out the clutch, you can reduce the noise or eliminate it.
Yeah,the clutch makes more noise on a C5 than a C4!!! But the C4 6sp tranny makes allot more Noise than the C5 6 sp tranny!!! Some of them don't hardly make any noise,and some of them Sound Like a Rock Crusher!!!do they all sound that way or more then others?
I have 3 C5's here on the lot with 6 sp's. 1 is Quite as a Church mouse and the other 2 are a bit noisy!!I have 1 C4 with a 6 sp and the Transmission sounds like a pick up Truck in Duel Low taking off!!!
The noise on a C5 puts me in mind of a Diesel rattle but not as pronounced!!do they all sound that way or more then others?
