Well phase one is well underway. Old transmission is out. Only a few minor problems, the cooling lines wouldn't come loose at the trans. Ended up cutting the lines. Dropped the cap off the u joint when removing the drive shaft, so the needle bearings ended up in the oil dry. Getting the dip stick tube wiggled out was a pain. Had to pull the distributor to get access to the top bolts of the bell housing. Had to sawzall my new welded exhaust behind the cross memeber. One the good side if there is one, the fly wheel had several teeth chewed up so while there might as well fix that while the tranny is out. All in all not that bad, had a couple of helpers rolling around in the tranny fluid with me.
