Your posting at 9:30 pm cdt and your gonna do it tonight yet ?
When do you sleep?
Glenn
What?? Miss out on taking 2 days of bonding with your Corvette to do a 1 1/2 hour job!!!If it were mine I think I would leave it.
Glenn
I am not familiar with the automatics as I have a six speed but you could have a rear seal out,considering that the yoke is slinging the oil. It could also be a leak around the speed sensor. Always possible that the gasket for the tail shaft housing is leaking. Are you sure it didn't come from the pan gasket area? With air turbulence under the car the oil follows some strange paths. With the fill tube leaking it is hard to say where the oil ends up.
I have had poor luck with any rubber gaskets on engine or transmission, seems like the screws work loose or the gasket shrinks. I have put most transmission pan gaskets on dry .The dark fiber looking gaskets are quite good if the pan isn't dented at the bolt holes from over tightening .
Glenn
Hi josh, Seems strange. I see capacity as 4.5 quarts. Is the pan stock, is the dipstick the correct one ? Roger.
