MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
I'm about ready to mount my external transmission filter. I have a few different options, with different pros and cons. So basically, I'm asking "if this was your car, what do you think would be easiest and best?"
Option 1 is to mount the filter vertically. This gives the advantage of being able to pre-fill the filter with fluid, whenever it is replaced. That eliminates air in the system, and the need to add another quart of ATF after the thing has run a few minutes and filled the filter on its own. But the downside is that it makes finding an appropriate mounting location difficult, to say the least. The filter needs to be somewhere forward of the cooler line ends (which are just aft of the swaybar), and there are few places near there which are tall enough to keep the filter bottom away from rocks (or curbs, if a mechanic or someone pulls too far forward).
Option 2 is to mount it horizontally. This makes finding a mounting location snap - it will easily go right below the lower radiator mount, tucked up there where it is protected. But it means that the filter can't be pre-filled with fluid.
Option 3 is the more complicated one. It would involve building a bracket with a pivot/hinge in it, so the filter could be mounted horizontally under the radiator, like Option 2, but with a cotter pin to retain it in that position. Pull the pin, and swing the filter down for changes. Since it would be vertical at this point, the filter could be pre-filled.
The third option obviously has several advantages, but there is always the risk (however small) that something which is made to come loose for maintenance, might accidentally come loose on its own, or by a stupid mechanic playing with it. If it did drop to vertical, in that location, the filter would hang well below the air dam, and be very vulnerable. The risk is small, but it does exist.
So, those are the options. Any thoughts?
Joe
Joe
