tat2ed
Having a problem with the trans not pulling all the way up to the bell housing. The spline tool goes in fine and before I installed the pilot bushing, I checked it for fit on the input shaft. Everything was fine there. I already have the bellhousing mounted to the engine. Should I mount the bell housing to the trans and then mount to engine? Or would it make no difference. By the way, the engine and trans are out of the car. Thought that would help when I went to put it together but I was wrong.It seems to go into the clutch fine but wont go into bushing. Don't want to wiggle it to much because a bolt on the trans was marring the bellhousing opening. Any help would be appreciated.I'll be glad when this project is over.
Thanks,
Jeff
Thanks,
Jeff
