AussieCorvetteNut
Hi guys,
I wanted to know if anyone could help me source a conversion kit (excluding tremec transmission) for a TKO 500 or TKO 600, to replace my DNE 4+3.
I have decided to pull the engine and 4+3 out of the 84 and rebuild the engine, but upgrade the transmission to tremec.
I have two DNE 4+3 Transmissions, but I can't guarantee that I will get overdrive if the electrics do not work, so I am ditching the 4+3's.
Hib Halverson suggested a Richmond transmission, but I cannot get anyone from richmond to respond.
I can get the tremec transmission here in Australia as the Aussie Dollar is crap at the moment and a $3500 USD transmission will cost $4850 AUD coming through customs. ad
Try getting that past the Wife...:eyerole
I only need the conversion kit with 31 spline yoke, torque arm adapter, rubber isolator mount, electronic speedo adapter, reverse light adapter, needle pilot bearing, shifter boot/ shifter handle/ 5 speed ball, tunnel modification template/ plate.
The selector is still on the left side, the right hand drive conversion hasn't changed any of this.
SST have a conversion only kit, but I am still waiting for final prices...still not the cheapest so far from early figures.
The 4+3 had gear oil in the trans cooler lines...:ugh
Appreciate your help.
Cheers Tony
Cheers Tony
