Trivia Question
only one is correct, a damaged air filter will likely cause:
  • Rough idle
    Votes: 0 0.0%
  • Incorrect MAF readings
    Votes: 0 0.0%
  • Increased wear on cylinder walls
    Votes: 3 75.0%
  • Overheating
    Votes: 1 25.0%
  • Total voters
    4
  • Poll closed .
FrankM
Derry, NH
A damaged air filter will likely cause:
1: Rough idle
2: Incorrect MAF readings
3: Increased wear on cylinder walls
4: Overheating
only one is correct
Tom73 said:
Damaged as in How?
only conclusion for the type of damage would be that "air is breaching the filter", any restriction to the air filter would not cause any of these symptons.
It seems the majority of us got this one correct. It is #3.
#1 would not be caused by unfiltered air.A restricted filter would cause lack of engine's ability to increase in rpm's. (can't breathe)
#2 the MAF only reads what ever gets past the filter
#4 incorrect air supply will not cause overheating
This also can illustrate how inferior air filtration can cause engine wear. It won't manifest itself until the miles get up over 100-125k maybe more on borderline air filtering systems. Of course no air filter would hasten the wear.
