I have a '69 with what I believe is a 427/390 4-speed. I do not believe the motor is the original but I'm having trouble putting the codes together. The following is what I know:
Engine casting # 3963512 date is J 23 8. Cannot make out pad #'s
My research shows this to be a late 69 427, or 70 454 but made in Oct. 68
VIN is 194679S708616 which means to me as an early 69
Intake manifold is cast 3955287 with a date of G 25 9
My research says this belongs to a 70 454/390HP
The exhaust manifolds are correct for 69
Carburetor is a quadra-jet with the number 7044230 and date 0584
My research says this is for a 74 Cadillac with auto trans.
Transmission has a casting of 385323 and the bell has 3899621 and the tail has a 3846429
I can find no info on the transmission codes
There is a D22 code on the upper right corner of the trim tag located in the door jam if that means anything.
It seems to me that I have a bastardized engine but would like to know if anyone could shed some light on what I have and if the parts I have are compatible. Or should I change the intake and carb? Also any help on the transmission numbers would help(is it a m20,21,22 or something else). Is the vin stamped on the trans and where is it located?
I know this is long but any help would be appreciated.
Thanks in advance,
gb
Thanks in advance,
gb
)On the passenger side of your Muncie should be the vin number to the car it was installed in.Near that number is another number that has a A , B , or C in it.
