captainrags
Decided to replace the distributor cap quite a preformence and replaced all new plugs AC 41-943. After finishing it would not start so used some starting fluid with no air cleaner on it sounding terible and missing would not start with out using the starting fluid so decided to remove the distributor again to check proper placement and found no problem started again and got code 350?. # 5 not firing removed that plug it looked good, did spark checks on 2-4-and 5 all had spark run it again got code #300 Radom multiple cylinder missfire.
Can sombody give me info on this issue please as I had blown a radiator hose prior to all this work I am suspecting coil and or moudle.
LT 4 1996 99,000 miles.
