Turn signal indicator lights do not work, in my 79
stevolwevol
Michigan
1977 light blue
I just picked up a 79 L48/350hr/370:1 gears. Paint is original, and great, interior is very good, all original. 67,000 miles. It has the original exhaust as well, I'm getting duels on Thursday. I have a few little issues, one is the turn signal/hazard lights don't work. Can anybody tell me the best way to correct this?
asset.php
First check the fuses and the connections ( diagrams can be found online). If all is good you will have to change the [FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]Turn signal switch.[/FONT]
Yes for the Turn and Back up
Well, my backup lights work, the turn signals work also but the green dash lights that indicate do not. I am concerned that the dash will have to be removed if the bulbs are burned out.
Sounds like the
bulbs are burned out...
