Hi there,
The bulletin number is 01-08-42-001, and the following is taken directly from that bulletin.
Some exterior lamps, such as cornering, turn signal, backup, headlamps or tail lamps may exhibit very small droplets of water, a fine mist or white fog (condensation) on the inside of the lamp lens. This may be more noticeable on lamps with "multi-lens" designs and may be normal during certain weather conditions.
Condensation occurs when the air inside the lamp assembly, through atmospheric changes, reaches the "dew point". When this takes place, the moisture in the air within the lamp assembly condenses, creating a fine mist or white fog on the inside surface of the lamp lens.
Most exterior lamps on General Motors vehicles use a vented design and feature a replaceable bulb assembly. They are designed to remove any accumulated moisture vapor by expelling it through a vent system. The vent system operates at all times, however, it is most effective when the lamps are ON or when the vehicle is in motion. Depending on the size, shape and location of the lamp on the vehicle, and the atmospheric conditions occurring, the amount of time required to clear the lamp may vary from 2 to 6 hours.
Condensation
"A fine mist or white fog on the inside surface of the lamp lens occurring after a period of high humidity".
May be located primarily in the lens corners (near the vents) and SHOULD NOT cover more than half the lens surface.
The condition should clear of moisture when the vehicle is parked in a dry environment, or when the vehicle is driven with the lights ON.
A comparison of the equivalent lamp on the opposing side of the vehicle indicates a SIMILAR performance.
If the above conditions are noted, the customer should be advised that replacement of a lamp assembly may not correct this condition.
Water Leak
"Numerous & various size drops of water collecting on the inside surface of the lamp lens after the vehicle has been exposed to rain or a car washing environment".
A condition that covers more than half the surface of the lamp lens.
An accumulation of water in the bottom of the lamp assembly.
A condition that WON'T clear when the vehicle is parked in a dry environment, or when the vehicle is driven with the lights ON.
A comparison of the equivalent lamp on the opposing side of the vehicle indicates a different performance.
Any of the above conditions would indicate the need to service the lens or lamp assembly
I hope that this will help you take care of your concern.
Allthebest, c4c5
