turn signals
  • Thread starter Thread starter winscheldc
W
winscheldc
I have a 1969 350/300. My question is regarding my turn signals. They both worked well on the dash and outside lights. Now, when I turn them on I get nothing anywhere, no green lights on dash or signals on front or back. I have replaced the fuse, I know it's not the flasher because I would at least have green lights showing on dash.
I have been working on replacing instrument cluster, etc. Are there any wires down there I might have pulled out or do you think the turn signal switch itself all of a sudden went bad? Or something else?
Any help would be appreciated.
Don
Is the plug in the steering col. secure (the long flat one )? Also I'd check the flasher unit anyway just so I knew.
Check the flasher - it feeds the indicator lights in the cluster as well as the outside lamps.
