I left this to long...
But how am I stupid for suggesting a engine? Jack if you have something to say come out and say it, don't use smilies like ;stupid to fight your battles. Please explain exactly how I was stupid Im a little confused there.....
HT 383 : 325Hp 415 ft/lbs ( 4500 rpm ) (3850$)
Crate engine, Gm warranty and HUGE room for mods because of the very well built bottom end. Forged crank and 383 cui displacment. That means to me I can add heads, intake, Carbs of any size or shape and I won't risk hurting the engine. Thats pretty cool IMO.
But you may be right Im Stupid... Lets compare a few
"Fast Burn 385" 350cui 385Hp ( 5600 rpm ) 385 ft/lbs ( 4000 rpm )(4100$)
"ZZ4 HO" 350cui 355Hp ( 5250 rpm ) 405 ft/lbs ( 3500 rpm ) (3500$)
Lets try injection
"Ram Jet 350" 350Hp ( 5200 rpm ) 400 ft/lbs ( 3500 rpm ) ( 4600$ )
Those are just a few I have listed hmm pretty comparable prices are all close and the Hp varys only 60Hp and Torque is only 30 ft/lbs...
Lets try a custom job..
(Prices from Campbells Performance Engine and Pro Stock Racing Enignes.) <--- Both prices were Identical as were the components for the most part.
383 Stroker ( 4100$ )
Edelbrock Performer heads
Edelbrock Performer Intake
Lunati Crank/rods/Pistons
Crane (Or your choice ) Cam
Stock dressings (Water pump, pan, gears etc..)
Limited 1 year warranty (Void if any part is installed by you it has to be done by Campbell or Pro Stock)
And ya and YOU provide the block
In the end it doesn't matter all the engines perform in the same league and the cost is similar.
But Im ;stupid
This is the HT 383 after Hotrod was done with it
500 lb-ft at 4,200 rpm and 460 hp at 5,400 rpm. That’s gruntin’ for a daily driveable 383.
