daved2
Hey guy's I have a big problem and I have a Service manual. When it talks about releasing the lock tab on the TV cable I'm stumped!
I have no tab on my 1992 LT1 automatic 700r4.
When I hit my throttle the TV cable bottoms out before the throttle reaches it's full throw and I can't find any way to change it.
I need a 92 experts advice on this situation I am in. The guy who I got the car from had the whole ASR motor apart and I think he put something back together wrong because the TV cable should not bottom out before the throttle does and keep me at only 80% throttle with the pedal an inch and a 1/4 off the carpet and not going all the way down. I can see the TV cable and the whole cable moves plastic casing and all and bottoms out. It has a metal clip on it holding the cable together and when I take the clip off and pull it apart there is an O-ring and that's it no type of adjustment and the whole sheath moves inward when it bottoms out at 80% throttle. The book says there is a lock tab that should be parallel to the cable and you are suppose to flip it up, well I don't have a tab so I am going nuts trying to get this thing right.
I don't think the whole outside ( plastic coating) of the cable shouldn't move when the throttle is depressed just the inside steel cable should move, that's the way all other cables work anyway. I've never seen a cable work like this one does.
Any help would be greatly appreciated!
Thanks ahead of time for your time!
Dave D
Dave D
