B
b2758
Noticed that the nuts on u-bolts on the upper joint of the right half shaft are touching an ear on the back of the differential. It had worn the edge off of it. I replaced all the u-joints and the rear spring links but it didn't change any. It's not causing a problem that I'm aware of but I know its not right. Any ideas about whats causing this? The left side has good clearance and I compared the u-bolts , they are the same.
