ultimate exhaust
  • Thread starter Thread starter fatboyreyn
F
fatboyreyn
Well guy's after 12 months and tons of money I have came accross what I think is the best c4 exhaust. I was looking for loud at WOT without interior resonance when cruising. Not an easy feat. I have finally ended my search with the following system. Comments are welcome.
Front true dual 2 1/4" y pipe from Corvette Central.
Rear y pipe, true dual, also from Corvette Central.
and the main part: Flowmaster "Delta Flow" 50 series mufflers with chrome tips, purchased from a place called Performance Peddlers.
The drawback is there is no longer a Cat on the system. The up side is my 86 coupe sounds SPECTACULAR and interior resonance has been ELIMINATED!!!
I am so happy I could cry.
First I have heard of no resonance with Flows. cool :cool
Don't get caught on the streets w/o the CAT. It's a huge FED fine. :w
How much is the fine?
If a Canadian goes to the US and gets caught without a cat, is there a fine? I go down to the US all the time for all the good deals.
I mentioned this on another forum, if you don't have cats you'll never pass the state inspection in NJ. They start with a visual check of two items; your exhaust and the check engine light. If there are no cats or the light is on you fail, the inspection stops and you're sent home. Nothing else is checked.
I have a '96 LT4, X-pipe, tru-dual 3" pipes, Magna Flow 3" mufflers, no resonance. X-pipe is the secret! Made by some people in south Florida, doesn’t have the normal small block F-Master sound, really turns heads
I've got 2 1/2" true dual exhaust with an H pipe. Mufflers are V-Force with 2 1/2" inlet and dual 2 1/4" outlets. They is some drone depending on speed and engine RPM, but the sound is great.
I'm confused...
...Front true dual 2 1/4" y pipe from Corvette Central.
Rear y pipe, true dual, also from Corvette Central...
How can it be a Y-pipe and a true dual? True dual sounds to me to be two pipes all the way back. Whereas, a Y-pipe indicates that two pipes merge into one. If you have a front Y-pipe and a rear Y-pipe, then you go from two to one and then back to two. That's not my definition of "true dual".
Am I missing something? :confused
Jim S. :w
Jim S. :w
Jim, I agree with you. Maybe I am missing something too. :)
You're probably okay, but CA does a visual. I understood that the EPA fine is $2500.
Jim S. :w
I'm in agreement with you. As in my post above, I have two 2 1/2" pipes running from the manifolds back to the mufflers. No Y pipes. That IMO is a "true" dual system.
