A
aaron1
Just like everybody else I am trying to get my car finished and on the road to have some enjoyment with. However, I am really frustrated with the lack of progress.
My car is a 78 with l48. I needed a new radiator. so I find an aftermarket one, however its a replacement for the heavy duty radiator. I did not think there would be any issues with this as it might help with extra cooling. I got new cushions for the wider seat of the new radiator.
I can just barely get the radiator into position without the fan shroud. Yesterday I found that you have to r+r the radiator with the fan shroud as an assembly. I was told that its listed in the AIM. I looked carefully in the AIM and did not see any mention of this. I also looked in the GM service manual. nothing. I tried this today and it will not work.
Someone on another forum said to rotate the frame the condenser is bolted to forward and the fan shroud and radiator should slide in. In order for this to work the hood needs to be removed. However its just me! How does just me remove the hood and then put hood back on without doing any more damage to the paint or hood?
I do not want to mess with the hood. Since my car is not a show car or trailer queen I thought about taking a saw to the fan shroud an making an upper half and a lower half. Why is it that in 78 only the corvette had a one piece fan shroud? I am sure I can fab up some tabs to lock the two halves together. All new GM vehicles haves a two piece fan shroud and they do not have cooling issues.
Has anyone customized their corvettes fan shroud? Anyone have any reason not to?... other than trailer queens.:eyerole
Please! give me some feedback.
aaron1
