R
Red76Vette
Dose any one else have problems with the hood unlatching my 76 unlatches all the time. Any adjustments I could make.
Thanks,
Chuck
Thanks,
Chuck
Nut said:91,000+ miles and she's never unlatched while driving. well over 100K miles on the old '72 and never an unlatch.
........... Nut
OUCH!!! :L :L :L69MyWay said:Clearly this is a function of horsepower vs. tensil strength of the car! So, I don't want to point out what that means to you Nut!!!!!!!!:L :L :L
Nut said:Oh.... I see. My whimpy little (modified to) 239 hp shark couldn't shake the hood loose let alone much else huh? A little upiddy down there in Orange Park this week?I guess I'll have to start working the hood loose so I can join the club.
................ Nut
69MyWay said:They are easy to adjust. The problem is, if you adjust them to latch very snug, you run the risk of it getting stuck latched!
I had that happen on my 74, and we ended up having to cut an access hole in the inner fender, etc. and it was not pretty. I was also 16 years old at the time, and this hampered my cruising activity with the car for the weekend. So, I said, nuts to that on my 69 and went with an adjustment on the light side. Since verts flex much more than t-tops, when I hit jus the right kind of angle, my frame will twist a tad and release the right side.
So, I just leave it down, but not latched anyway (note, I have the short hood). That way (especially durning my new engine/car etc. break in phase), I have quick access to the motor and don't have to worry about anything going crazy with the latch and sticking closed.
WayneLBurnham said:I thought that's what the 8 pound sledge hammer I carried was for...
Be happy it's just the hood - and not the convertible deck...
...I am getting unnerved at the thoughts of that thing popping loose...the World's weakest, decapitating airbrake....one side would almost CERTAINLY break loose first and swing that puppy around in the airstream like a two-handed sword....
