Bernie (BWmurph) came over after work to help me with some reassembly
As we were putting on the valve covers I was tightening them down to proper torque spech with a in/lb torque wrench. It wasn't even close to tight yet and CRACK, the cover cracked across the mounting nole. It's like a semi-circle from one side to the other around that one mounting spot on the cover.
Bernie looked at it as he was taking it back off (because I was too busy cussing up a storm) and confirmed that screw wasn't even tight yet so it's not like I overtightened it by accident.
He has people at his work that do aluminum welding. Do you think a valve cover can be repaired by aluminum welding than buffed out and glass bead blasted to make it work AND look acceptable?
If not......... does any forum member have one, or a pair of proper valve covers for a '65 L76 (the aluminum ones) WITHOUT the casting flaw in them that they are willing to sell or know where I can get a set quick? I checked and there are not any on eBay that would be acceptable. The only ones I saw had broken fins.
