TedC,
Thank you for your feedback and valuable insight in the solution of this issue. Your corroboration of my limited findings and partial results will prove useful to future CAC members researching EGR problems.
To me at least, ever since I replaced the EGR valve in "Gail", she gained a little over 1/2 Hg-In of vacuum at idle and she seemed more responsive. And as I recall, the EGR valve was not that expensive at all.
As far as the "pinging" that you experienced by manually closing the EGR valve in light acceleration, I theorize that the computer is scheduling a predetermined advance timing at that point, and since you were by-passing the control of the EGR, the resultant was the pinging (the air-fuel mixture was supposed to be diluted by the exhaust gases if the EGR was open, but instead, there was "wrong" advanced timing for the relatively-rich fuel mixture charge). Furthermore, given the fact that our Vette engines lack a knock sensor, the computer could not detect the pinging when it happened (which on a knock sensor system, once detected, the ignition timing gets retarded until it goes away).
I am trying to keep it straight in my head, but if a relatively rich fuel mixture (only so because the exhaust gases are not being added) requires more time to burn, then by preventing the exhaust gases from mixing with the fuel charge, the timing that the computer had scheduled was not enough??? :confused
And if so, wouldn't that mean that if the scheduled timing by the computer was not enough, then more timing would have been required, and thus the "pinging" shouldn't have been present to begin with? But you heard the pinging, so the advanced timing perhaps was too much even at that point where the relatively rich fuel mixture charge was being employed (in other words, the predetermined advanced by the computer was too much still)? So, could it be that since you were closing the valve manually with the vacuum pump, that the engine was not employing or loosing vacuum signal to open the EGR valve, and perhaps given the higher vacuum signal, the pre-determined timing by the computer was too much still, and thus the pinging your heard?
Wow, talk about deep...too deep for not having fresh alcohol in my system right now...:L
We may need someone with thorough understanding of this process to help us explain why you got the pinging when you closed the EGR valve in light acceleration. ;help
GerryLP:cool
